Maybe you should buy the H.
Posted by steve from mo - dangit! on January 17, 2007 at 09:00:43 from (168.166.54.11):
In Reply to: Farmhand Loader posted by ruready1 on January 17, 2007 at 04:01:06:
You could put that on an H and save your C. There are a lot of H tractors out there and a good plain running H doesn't cost that much.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
