Re: Farmhand Loader
Posted by RustyFarmall on January 17, 2007 at 11:26:14 from (207.32.13.249):
In Reply to: Re: Farmhand Loader posted by ruready1 on January 17, 2007 at 11:00:51:
That C you have now should be easy enough to sell.
If you will clue us in as to just what you need the tractor for, we can make a few suggestions as to the makes and models that would be appropriate.
The first suggestion I will make is that if you need a tractor with a 3 point hitch, you really need to be looking for a tractor that offered the 3 point as original equipment. The aftermarket add on stuff is OK, but is not as good as factory installed.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
