Re: Farmhand Loader
Posted by Janicholson on January 17, 2007 at 12:06:35 from (199.17.6.122):
In Reply to: Re: Farmhand Loader posted by ruready1 on January 17, 2007 at 11:00:51:
The primary input I would give is that there may not be the "old" red tractor meeting your needs. It sounds like you need a Kubota with loader and class 1 3pt hitch and assorted implements bush hog and blade. 5000 might buy the one on Ebay. The tractor you have will sell to someone who needs it, Cs are very nice for 15 acres of truck patch and having a small tractor amid some bigger ones. Not to worry. JimN
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
