Re: Super C hydo's
Posted by Steven@AZ on January 17, 2007 at 17:48:32 from (24.121.155.253):
In Reply to: Super C hydo's posted by Andrew Z on January 17, 2007 at 14:05:08:
WHOA!!! Wait a minute! You have 30 weight oil in your Touch Control Super C??? No good, way too thick. Drain that out ASAP.
That system is designed for what IH used to call "Touch Control fluid" but now Hy-Tran is what you want. Another oil/fluid rated for hydraulic use would be fine as well.
