Re: Super A hydraulics
Posted by Tom Olson on January 17, 2007 at 18:14:56 from (24.166.129.72):
In Reply to: Super A hydraulics posted by ncpatriot65 on January 17, 2007 at 03:08:06:
If hydraulic fluid is leaking into the engine crankcase, it's relatively easy to replace the pump shaft seal. On most SA pumps it's a regular oil seal that will cost about $5.00 at an auto parts store. Mine used a Federal-Mogul/National part # 471466.
Remember that after removing the 2 bolts/lockwashers/nuts that hold the manifold tubes to the pump there are only 2 bolts that hold the pump to the engine. The other 2 hold the pump together. Looking at the rear of the pump, the upper right and lower left bolts are the ones to remove the pump.
