Re: Holes Behind Gear Shifter
Posted by Hugh MacKay on January 18, 2007 at 02:45:14 from (216.208.58.109):
In Reply to: Re: Holes Behind Gear Shifter posted by SuperA-Tx on January 17, 2007 at 19:26:29:
Tx; I just dug out a parts manual I have for an older disc plow, A-147, manual hand controls for A without hydraulics. It has a rod going to front axle, actually from the photo it lookd to go over axle and hook to tyrod. Probably a predecessor of the A-151, as there are disc plows in this book, namely; A-147, B-147, No.149, H-149 and HM-150.
I didn't take time to go into this in detail as I'm in a hurry this morning, but as I leaf through this 85-PO tractor plow book I see parts of A some hand lifts that bolt to those holes on top of transmission. It may just be rear rockshaft for hand lift.
