Re: Doing away with Oil Bath System
Posted by Janicholson on January 18, 2007 at 14:52:17 from (199.17.6.122):
In Reply to: Doing away with Oil Bath System posted by Steve Weathers on January 18, 2007 at 14:22:11:
Rusty Farmall is very much on target asking you why. The primary reason these tractors are still in existance is that with clean air, they last. An oilbath aircleaner is, in my experience, the finest filtraion system for these units. Everything other than this unit will require more maintance, or work less effectively, Don't do it. JimN
