Re: Doing away with Oil Bath System
Posted by JayWalt on January 18, 2007 at 15:30:49 from (24.223.138.48):
In Reply to: Doing away with Oil Bath System posted by Steve Weathers on January 18, 2007 at 14:22:11:
The oil bath system is the best filtration system for dusty environments (in a continuaing runtime situation, the dry just simply cloggs up to fast). Pulling is a dusty environment, albeit for a short duration.
I dont know how effective the oil bath system will be when ur front tires are in the air... should still work fine. One of the keys to the oil bath system is proper maintenance.
I dont think you will find ANY satisfactory dry filter that will fit into such a small cannister. The more flow the better, and a dry filter proper for that size engine is just going to be larger. Think about the surface area of the dry filters. The oil bath has a tube about 2" in diameter that goes into the oil bath. Now imagine this 2" diameter with a dry filter. There is not going to be much airflow.
If you are going to use a dry filter, it will be visible, thats all there is to it.
