Re: B414 Won't Start
Posted by El Toro on January 20, 2007 at 06:52:35 from (64.12.116.65):
In Reply to: Re: B414 Won't Start posted by Paul(NS) on January 20, 2007 at 06:33:14:
I have never replaced a solenoid. Someone else that post on this forum may have had a problem.
The only problem I had with solenoid's were corroded cable connections. That corrosion will act like an insulator. Take a look at new one and give it a good shaking that may be normal. One other thing I had with them were the brass
discs inside the solenoid from all that arcing when you make a start. I just rotated them so they had a new area to arc on. It was usually very hard to do this on cars since you have very little room to work. I would pull the starter and sometimes I would just buy a rebuilt starter.
Hal
PS: Have you tried another good battery? I use the best batteries from Walmart that have the 3 year free replacement. They are about $70.00
with an exchange. I even have one on my garden tractor and its about 5 years old.
