Re: 300U Hyd?
Posted by Janicholson on January 21, 2007 at 08:08:46 from (66.173.50.82):
In Reply to: 300U Hyd? posted by TDH on January 21, 2007 at 07:55:54:
Assuming it has 3 valves on it now, on the right side of the seat. (or places valves could be) purchase a IH valve that is a pass through valve (inner style) and put it on. Connect to the cylinder ports and you are done. If it has no valves it will have plates over the ports for valves and a single (outer) valve will be needed. If it has no valves, it is possible to thread the ports in the block and connect hoses there so a remote valve, or quick disconnects could be used. It would need supply and return to keep it happy. I do not have the diagram, it is 900 miles away. JimN
