Re: Farmall M V8 conversion kit
Posted by willywonka2 on January 21, 2007 at 10:09:02 from (152.163.100.65):
In Reply to: Farmall M V8 conversion kit posted by Bob Vigar on January 21, 2007 at 08:07:18:
its not to hard to v8 an m. we built with a 700+ hp small block chevy and turned it 8000 rpms to pull with. did really well with no breakage. we did needle the diff. the stock m engine makes a whole lot more torque than the v8 in the given rpm range so if your going to farm with it i would probably fix the stocker or maybe swap in a 3.9 or a 5.9 cummins.
