Re: 1086 differential lock
Posted by RR Mech on January 21, 2007 at 20:30:58 from (12.154.7.21):
In Reply to: 1086 differential lock posted by emhoff on January 21, 2007 at 19:46:09:
Yes its a switch about like the old M starter switch. You hold it down to engage a hydraulic valve which applies pressure to the diff. lock that is mounted outside of the right brake. It hooks the two diff. parts together through a hollow shaft. As soon as you release the button it releases the diff. lock.
