Re: jump start 806 diesel?
Posted by Hugh MacKay on January 22, 2007 at 02:49:58 from (216.208.58.154):
In Reply to: Re: jump start 806 diesel? posted by Harlen Larson on January 21, 2007 at 17:47:21:
Harlen: No question, and I guess that would be the best advice for all situations, hook positive to the positive lead to starter and negative to negative that has ground strap to the frame. My concern was being sure he was taking in the entire 12 volt system rather than one 6 volt battery.
I guess if one hooked to a single 6 volt battery, and both 6 volt batteries had some charge, the worst you may do is put 18 volts to the starter. years ago we never hesitated to hook 12 volt up to jump the old 6 volt Farmalls. I know numerous guys that never hesitated to put 24 volts to those 6 cylinder diesels. I'm not sure folks should be trying that on the newer tractors with digital everything and sensors galore.
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
