Re: Het Randy I A
Posted by Janicholson on January 22, 2007 at 06:56:50 from (199.17.6.122):
In Reply to: Het Randy I A posted by thumbanger on January 21, 2007 at 18:10:40:
I think I have it figured (maybe) Assuming From this post, that your tractor has a live hydraulic pump at the distributor the cap was adjustable so that air could be drawn into the resivoir when used as a one way live hydraulic system. And closed to use it as a two way system because the vloume in the two way stays constant. If your tractor has a belly pump and no live pump, then it has the wrong cap on it. If your tractor has a combination of belly pump, live pump, external resivoir and Xmas tree valve, I have no Idea which cap is where used for which system. JimN
