Re: A Electrical Question
Posted by Janicholson on January 22, 2007 at 08:56:21 from (199.17.6.122):
In Reply to: A Electrical Question posted by plh_in on January 22, 2007 at 08:43:45:
That heat is the evedence needed to tell the story. The cable may be too small, or corroded at the terminal. Cables on that tractor should be made from thick wire (many get replaced with auto grade cables) the designation is "O" gauge wire Or if it is a bigger tractor than youre #OO gauge is used. The heat should not be there. The battery may be OK, I would not suspect it until you replace the cable and it still has issues. Another way to assist the cable you have as a test, is to use good 4 gauge jumper cables to add conductivity to that heating cable. Just connect to both ends of that cable with one of the jumper leads to increase its conduction. If it does better, it points out the problem is as indicated. If a new cable does not make it start better(but prevents the heating at the wire), the starter motor may be dragging. This is caused by worn bushings in the end frame on one or bothe ends, allowing the armature to physically drag against the field poles. If this is tha case it will still turn slow, and needs to be rebushed and a new set of brushes installed. Good luck, JimN
Home
| Forums
Today's Featured Article -
Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
