Re: A Electrical Question
Posted by El Toro on January 22, 2007 at 09:06:21 from (152.163.100.65):
In Reply to: A Electrical Question posted by plh_in on January 22, 2007 at 08:43:45:
I would use at least 0 size battery cables. You need to measure the specific gravity in each battery cell to see what the state of charge is.
Readings should be 1.250 or higher and each reading should be close to one another. I only use the batteries from Walmart that has the 3 year free replacement. I even have one on my garden tractor its been on there for 5 years.
Make sure your charging system is working too. With the engine at 1/2 to 3/4 throttle measure the voltage at the battery. Should be around 14 volts. Hal
