Re: alternator belt on H
Posted by Delbert on January 22, 2007 at 17:02:24 from (65.164.58.28):
In Reply to: alternator belt on H posted by banjo on January 21, 2007 at 20:06:48:
Use the ac alterantor and your genny pulley you will have to drill and tap the alternator and put a bolt in the end to hold pulley on use a 3/8,s inch bolt. Then use about the same belt as with the genny. You can adjust the belt no problem. Might even use same bracket as the genny to suport aternator.
