Yes you are missing the one part that goes on the clutch output shaft and the one that goes on the input shaft for the overdrive. there is also a spacer that goes inbetween the two and bolts them together. It also takes a shorter clutch output shaft to make everything work. I slid my engine forward a few inches to change out the back plate on the back of the bell housing and install the shorter clutch shaft. Hope this helps,
