Re: M overhaule
Posted by El Toro on January 23, 2007 at 14:12:20 from (152.163.100.65):
In Reply to: M overhaule posted by james braley on January 23, 2007 at 13:18:05:
I would agree with Old on tearing the engine down. You need to measure the crankshaft or have
it measured at your local auto machine shop. To be sure you are going to have good oil pressure you need close tolerances on the rod and main bearings. The same on cam bearings. Those sleeves need to be measured too. If they worn beyond the wear limit I would install a new sleeve kit. Check that oil pump for wear too.
You don't want to have to pull that engine apart the second time. Hal
Today's Featured Article - The Fordson F Ignition System - by Anthony West. A fellow restorer contacted me earlier this year asking for some help and advice on a model F that he was restoring. He had over a period of months spent a fair amount of his hard earned cash on replacement parts for the old "trembler" ignition. Sadly though all his efforts seemed to be a waste of time and money as he still couldn''t get the temperamental old thing to run correctly!! If i said that this was a little frustrating for him that would be "conservative" in fact the problem had reduce ... [Read Article]
