Re: B-275 IH
Posted by Hugh MacKay on January 23, 2007 at 16:03:20 from (216.208.58.127):
In Reply to: B-275 IH posted by N. L. (MS) on January 23, 2007 at 14:04:57:
N.L.: While that model was only built a short while, the same basic chassis and engine lasted for many years. IH built those until the buyout by Case in 85, then Case continued it for awhile. The last I heard on this Mahidra of India was still building it into this century. I expect parts are probably as readily available for that tractor as any other model out there. About all that ever changed was the sheet metal.
They were an iron clad little machine, diesel was a bit rough on starting in cold weather. I'm talking Canadian cold weather.
