Re: removing frozen silage from silo walls
Posted by GeneP on January 23, 2007 at 18:02:58 from (216.74.196.145):
In Reply to: Re: removing frozen silage from silo walls posted by Fromjb2 on January 23, 2007 at 17:28:32:
You didn't mention if it was plaster or epoxy coated. I would guess epoxy would be easier to damage. Ours is plaster, although we havent filled it for 10 years we did use it for better than 20 years. We always had to get up there with an old ax. Try to catch as warm a day as possible and manytimes I have seen huge slabs come off. We had a silomatic and it also had chippers and did a pretty fair job of keeping the frozen silage to around 3"
Good luck, I feel for you, Gene
