Re: Uh-Ohhhh, anti-freeze in the oil, 54 Super C?
Posted by Janichoson on January 24, 2007 at 14:22:47 from (199.17.6.122):
In Reply to: Uh-Ohhhh, anti-freeze in the oil, 54 Super C? posted by tractorsam on January 24, 2007 at 13:52:54:
The "O" rings at the bottom of the sleeves are more commonly the problem. They need to be lubed with dish soap on the way in. some are not, and get nicked. Loose at the top is also a problem. They should be so snug that they just don't move, not a driven fit. If the maker of the sleeves is unknown, and not able to be held accountable, Or if the block was bored for the oversized sleeves, then fixing it may be the only recourse. I would put a thin film of petroleum jelly on the sleeve rim, coating it well on under surface, and sides, Then use JB weld in the groove such that it smashes out and up creating a seal at the top that will hold the sleeve in place. Both ends need to be sealed to prevent leakage. Normally the top is sealed by the sleeve rim, but on that one cylinder, it may be loose enough to become leaky. These are what I would do JimN
Today's Featured Article - When Push Comes to Shove - by Dave Patterson. When I was a “kid” (still am to a deree) about two I guess, my parents couldn’t find me one day. They were horrified (we lived by the railroad), my mother thought the worst: "He’s been run over by a train, he’s gone forever!" Where did they find me? Perched up on the seat of the tractor. I’d probably plowed about 3000 acres (in my head anyway) by the time they found me. This is where my love for tractors started and has only gotten worse in my tender 50 yrs on this “green planet”. I’m par ... [Read Article]
