workin' on the SC
Posted by Chris from Wa on January 24, 2007 at 18:11:55 from (71.212.9.80):
I finally tore down the engine on the SC. When the gear on the old hydraulic pump went, it took off half the teeth from the cam gear. It showered all of those down into the crank gear. What a mess. Anyway, the crank was in good shape otherwise, and cleaned up at 10 under on both main and rod journals. I got the block hot-tanked and it sure looks perty. Now I'm down to ordering parts. Keith-OR, that crank pulley puller sure did a nice job.
