Re: steering gear
Posted by Dave Sherburne NY on January 26, 2007 at 18:21:12 from (74.32.159.240):
In Reply to: steering gear posted by franklin on January 26, 2007 at 09:41:54:
I don't think there is such a thing as a used
tight steering box for an A. If you have an A You
probrobly have the vertical shaft with the square
end on the bottom. Thats the first place to check
for sloppiness. Check the tierod ends inner and
outer. Then you have to take the box off the tractor
That vertical shaft has a keyway for the sector
gear. That could be sloppy to. Then there are
bushings in there on all the shafts Kits are
available with all the necessary parts. Plenty of
Posts on this problem in the Archives. Heres a link
http://www.ytmag.com/cgi-bin/viewit.cgi?bd=farmall&th=552523
You can Email me with more Questions.
