Re: 806 Diesel Headgasket
Posted by Tom43 on January 27, 2007 at 12:47:42 from (70.142.49.246):
In Reply to: 806 Diesel Headgasket posted by trw on January 27, 2007 at 09:39:20:
Any time I have a head off I take it to a machine shop and have it checked for warpage and cracks. I also have the springs checked and the valves ground. This is also a great time to have the injectors checked for cracking pressure and spray patterns. I have seen many people regret not taking these extra precautions. The amount of labor is about the same and doing the job right the first time is a lot more fun than the second time.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
