Re: B414 Still Won't Start !
Posted by Fromjb2 on January 27, 2007 at 14:02:05 from (74.101.67.211):
In Reply to: B414 Still Won't Start ! posted by Paul(NS) on January 27, 2007 at 12:41:10:
Hi Paul, is the B414 gas or Diesel. I assume it is gas because the Diesel model had a manual starter switch. I looked in the B414 Operator's Manual wiring diagram for petrol model and it only shows a 3 terminal starter solenoid. The 2 big terminals for battery and starter, the other smaller terminal has 2 wires, 1 Brown wire(red sleeve) to terminal 3 of ignition switch, the other wire Brown going to Ammeter. Since you replaced battery and cleaned cable connectors at both battery and solenoid then you could have a grounding problem at the battery. Quick simple test is turn on the head lights and attempt to start tractor. If lights go out or really dim then there is a grounding problem from battery to frame. The other problem that would happen on the early Diesel model starter was that the only ground for the starter was thru the end bearings of the starter. There was a ground post on the front of the starter that was never connected to ground. Later models had a ground strap connected from that post to one of the starter mounting bolts. The other problem could be your ignition/starter switch being bad. Try this at YOUR OWN RISK. To test for this problem make sure tractor is in NEUTRAL and PARK BRAKE is ON, take a screw driver and short the small ignition switch terminal on the solenoid to the big battery terminal and starter should engage and spin the engine. One other thought, did someone retrofit a clutch safety swicth on this B414? Good luck JimB
Home
| Forums
Today's Featured Article -
Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
