Re: 806 Diesel Headgasket
Posted by the tractor vet on January 27, 2007 at 15:48:18 from (75.19.125.118):
In Reply to: 806 Diesel Headgasket posted by trw on January 27, 2007 at 09:39:20:
Well some of that is true in the post below BUT when takeing a D 361 head to a machine shop FIRST THEY HAD BETTER KNOW OF JUST HOW THE VALVES ARE TO SET IN THAT HEAD as grinding the valves deeper into there seats will turn a good tractor into a hard starter and low on power . Also torquen the head down in three steps then retorquen it HOT then again after fifty hours of run time IF the valves are aready setting deep in there seats now is the time to install new seats guides and spring keeper and retainers as this cheap insurance on not having a valve drop it's keeper and putting a valve thru a piston and scrappen out and engine.Run a bottoming tap into the head bolt holes and clean out any rust carbon then clean each hole with carb cleaner - either - laquar thinner any one of the three will work then blow out each hole with compressed air chase allthe threads on the head bolts and wire brush then when installing then use some white grease on the threads and under the bolt head between the head and the washer.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
