Re: B414 Still Won't Start !
Posted by Brent in IA on January 27, 2007 at 16:21:55 from (66.43.236.195):
In Reply to: B414 Still Won't Start ! posted by Paul(NS) on January 27, 2007 at 12:41:10:
It's a long shot but I had a tractor once that had the same symptoms, I replaced the starter with a brand new one and same thing. Turned out the previous owner had 20w50 oil in it, it was -20 degrees outside, and the engine was just too cold to turn over with the thick oil. Put a kersene heater on it and plugged the engine heater in and in a couple hours she cranked right over. Just a thought.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
