Re: Changing Rear Seal on WD6
Posted by chuck46 on January 27, 2007 at 22:21:29 from (64.136.27.229):
In Reply to: Changing Rear Seal on WD6 posted by tommy jones on January 27, 2007 at 18:38:08:
Hi, I am going to assume a 6 is similar to a 9. Take the fuel tank and front tank support casting off, remove clutch and flywheel. The engine seal is built in 2 pieces so it comes off easily, if I remember right you also have to remove the oil pan and a rectangle shaped plate between the pan and the seal bracket. Good Luck, Chuck
