Re: Low speed gears - H
Posted by Wardner on January 28, 2007 at 01:09:14 from (206.148.20.8):
In Reply to: Re: Low speed gears - H posted by Andrew Z on January 27, 2007 at 19:55:55:
Because the countershaft low-low first gear is so small, it is machined on the countershaft. In addition to that, you will need a different second-gear countershaft gear because the regular gear is a cluster gear with first and second made from the same chunk of metal. You will also need a new reverse idler gear. Finally, you will need a new mainshaft first gear. There may be misc parts such as spacers and bearings. There is a slim chance that tranny parts from a 460 will fit and give you a low-low first. I wouldn't count on it, but to be sure, you would have to consult both parts books. If it did work, it is likely that your PTO would not work. I mention the above because I installed 560 gears and bearings in a SMTA transaxle. I got a low-low first and, when it was multiplied by the lower speed differential, it is very slow. I did the math at some point, and first gear was less than half of stock. I think it was around .7 mph at rated rpm. The factory recommends that tractors (Farmall M) equipped with the low-low option use a wide front and four front wheel weights. I suspect there is some crop that used the low-low set-up. Perhaps a tree nursery for transplanting. I dunno. Maybe somebody else does.
Home
| Forums
Today's Featured Article -
Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
