Re: B414 Still Won't Start !
Posted by El Toro on January 28, 2007 at 04:22:08 from (205.188.116.133):
In Reply to: B414 Still Won't Start ! posted by Paul(NS) on January 27, 2007 at 12:41:10:
If it doesn't crank after doing what Fromjb2 suggested you should pull the starter and connect a battery to the starter. Then see if the starter
drive (bendix) is energized when you short across
(just touch) those small terminals on the solenoid with a screwdriver. Keep your hands away from that starter drive when doing this.
If that starter drive doesn't move. You prbably need a new solenoid. Hal
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
