Re: International 400 pto hiss
Posted by the Unforgiven on January 28, 2007 at 09:26:51 from (66.146.249.186):
In Reply to: International 400 pto hiss posted by MarkinAB on January 27, 2007 at 20:01:42:
Make sure it has oil in it, it does NOT share with the rear end, it has it's own. The level plug is on the left side, usually hidden by the FH cylinder. Some whine is normal, it gets worse fast if it is dry. When you turn the pto off the planet gears must spin, that is what you are hearing.
