Re: 1948 I-4 Brakes
Posted by Janicholson on January 28, 2007 at 17:12:34 from (66.173.50.139):
In Reply to: 1948 I-4 Brakes posted by flic50 on January 28, 2007 at 16:17:28:
I think they are the same as H. Local heavy equipment repair may be able to reline them. Common type of band brake used on sonstruction winches and cable operated cranes. Check prices of new and compare. Leaking seals may be a cause of failure, if leaking, stub shaft seals need to be replaced. A book is needed to avoid breaking parts!! JimN
