Re: SH Hydraulic Hoses
Posted by JayWalt on January 29, 2007 at 16:09:22 from (71.244.146.196):
In Reply to: SH Hydraulic Hoses posted by Mr. Mayor on January 29, 2007 at 14:04:32:
I knbow its not the ideal, but your local TSC (Tractor Supply Company) should have hoses. Bad thing is they arent swivel ends, so you will have to take that into acocunt,, but they are relatively cheap and rated 3000psi I believe. The short ones, like 2 foot are around 10$, not bad. Not sure what you specific application requires tho. They arent hard lines btw
