Re: International Super M-1951
Posted by Janicholson on January 29, 2007 at 16:37:04 from (66.173.50.128):
In Reply to: International Super M-1951 posted by Keith Jasinski on January 29, 2007 at 14:03:17:
First find out which cylinder it is. Pull off one plug wire at a time (using plug wire pliers or well insulated pliers) as each is removed and replaced, one will make no difference. That is the focus. Change the plug in that cylinder with another and retest to see if it followed the plug, if so replace the plug, if not, pull the plug from the cylinder that is not working and test the compression again (with throttle open) If good compression, we need to focus on intake. Use the choke to richen up the mixture till it begins to run rough (not full choke) and see if at some point the engine picks up that cylinder. If so there may be a vacuum leak letting air in that runner of the manifold. Use an unlit propane torch (outside) while it is running and missing. Pass the torch nozzle around the intake manifold to see if it picks up the cylinder. If so there is your leak. If not, I would pull the valve cover off and look at the valve train to see if a valve is stuck, or not moving. Worn out cams, misadjusted valves, and broken bent pushrods will cause that miss. Good luck, JimN
Home
| Forums
Today's Featured Article -
Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
