Re: 350 utility fan belt
Posted by JayWalt on January 30, 2007 at 00:19:02 from (70.226.20.153):
In Reply to: 350 utility fan belt posted by ih tractorguy on January 29, 2007 at 18:17:25:
if its like the 300 utility, and I'm thinking it is, u have to loosen the setscrew in the waterpump pulley and separate the 2 threaded halves of the pulley, which make the belt looser, and then you pop it off the bottom pulley and take it around each fan blade, and install is opposite.
Now you might be unlucky like me and either some idiot broke the setscrew off (like mine is!!), or when u get that loose, the 2 halfs wont budge. Luckily my fan belt is like new, it was the alternator belt i had to replace and I used a spliceable belt, but that wont work for the fan belt if you can tighten it.
Hopefully, it will come loose for you.. if it does, i would reassemble it with little antiseize and tighten the setscrew down good.
Hope this helps.
