Re: Super MTAD factory fast hitch or power steerin
Posted by Hugh MacKay on January 30, 2007 at 04:48:23 from (216.208.58.184):
In Reply to: Re: Super MTAD factory fast hitch or power steerin posted by allred1 on January 29, 2007 at 19:12:32:
alred1: Once you remove the standard drawbar the 450 hitch is a direct bolt up. The difficult part will be hydraulic control valve if you want draft control. That would have been the special order part 50 years ago. I doubt if you can buy the valve anymore. If you just want up and down hydraulics, then any double action valve will work, probably one with float position would be best.
