Re: pto on 560 wont shut off
Posted by Hugh MacKay on January 30, 2007 at 15:17:25 from (209.226.106.73):
In Reply to: pto on 560 wont shut off posted by International man on January 30, 2007 at 13:59:44:
This sounds all to familiar to me, I had a 560 years ago and when that happened the PTO was usually toast. Can you stop the PTO from turning by holding forward on PTO lever? If so make the adjustment in lever linkage as WI cowman suggests. That adjustment and forward notch on lever is the brake for the PTO. That failing you might try clutch pack adjustment within the PTO.
Do you know which type of PTO your 560 has? There were two, both looked very much alike on the outside. There was a change mid way in production, I don't know the serial number at change. With the early models the PTO had to be removed from tractor for PTO clutch pack adjustment. On late model tractors clutch pack adjustment was done through a 1.5" round hole in top of PTO. You should have the proper manual and try clutch pack adjustment.
You could have clutch pack adjusted too strong, thus it is over powering the brake. Fair warning though, they do the same when the unit is toast. I had my 560 for 17 years never got the clutch pack over adjusted, but I did rebuilt it every couple of years. Bear in mind my 560 was turning 90 hp all those years. 1954 to 1963 were the years of IPTO evolution, IH didn't get it right until 06 series tractors in my opinion.
Today's Featured Article - Harry Ferguson - The Man & The Machine Harry Ferguson was christened Henry George but every one called him Harry. Harry was born in a small Irish town called Growell in County Down about 16 miles from Belfast. Harry Ferguson led a varied and colorful childhood causing mischief where ever he could. He showed mechanical aptitude at a very early stage in life and showed no inclination towards ... [Read Article]
