Re: 350 utility fan belt
Posted by tom nj on January 30, 2007 at 17:01:27 from (68.167.68.65):
In Reply to: 350 utility fan belt posted by ih tractorguy on January 29, 2007 at 18:17:25:
If you have a hydraulic pump which drives off the damper pulley you have to remove the pump seperate the chain coupler and then unscrew the four bolts on the damper pulley and you can just get enough space to squeeze the belt through the opening. I'm doing mine right now I'm waiting for the belt to come from tractor supply. I called Dayco and Gates as well as International and no one had the belt except tractor supply. It's a 3/4" x 39 3/8"...good luck
