Re: pto on 560 wont shut off
Posted by Hugh MacKay on January 30, 2007 at 18:37:22 from (209.226.247.124):
In Reply to: Re: pto on 560 wont shut off posted by Tim Shaw on January 30, 2007 at 16:45:43:
Tim: I don't have much quarrel with what your saying. I have seen planetary type on 460s, I've not seen it on 560s, but then I never checked serial numbers of the ones I saw either. Maybe I've never looked at a very early 560s. My own 560 was a 62 model, thus I should have said I've never seen it.
With regards to the particular PTO in question, I've never seen a planetary with this symptom. Very common with the clutch type, therefore I think the question at hand is adjustment of the clutch type. Having said this, and while the two clutch type are very similar, the adjustment proceedure is quite different, thus I feel it is imperitive he find out which type he has, then find the proper manual for that adjustment. From the description, quite frankly I think his PTO is toast.
I rebuilt the planetary in my 300 several times in 35 years. I rebuilt the clutch type in my 560 at least 5 maybe 6 times in 17 years. Bear in mind that 560 was turning out 90 hp all those years and was worked accordingly.
