Re: How do you install a belly pump on a Farmall H
Posted by toolz on January 30, 2007 at 23:21:35 from (66.158.169.70):
In Reply to: How do you install a belly pump on a Farmall H posted by Neil Fuller on January 30, 2007 at 07:39:19:
First make sure you have removed the in/out pipes and dust shields, along with the lever. Then just use a floor jack to lift it into place and install the 4 bolts through the bottom to hold it in. Then install the coupler between the trans and pump, and re-install the pipes and lever. Very simple job. If you need a complete pump and tank, I have one I just took out of my H that I"ll sell for $100. I don"t have the coupler, but they are easy to find. Everything else is there. Email if you need it.
