Re: h clutch housing
Posted by D Slater on January 31, 2007 at 05:10:30 from (205.188.116.133):
In Reply to: h clutch housing posted by daniel gillespie on January 31, 2007 at 04:07:54:
Those are alignment dowel pins and the pins are tight enough there sometimes to hold center housing to transmission. Most times if threads are not batered up you can tighten nuts down enough that they start pulling out or spinning in hole and they can be worked out. Or if housing is in a position to do it, use a block of wood and big hammer on each side at front of housing until you get a crack between housings. Warning housings will break if hammered to much. Can't remember for sure on a H, but on a M those holes go all the way in to transmission and oil will leak at the pins if there not tight enough. So sometimes you find sealer on them which makes them tighter.
Today's Featured Article - Maintaining Rubber Tires - by Staff. The broad use of rubber tires on farm tractors and machinery has resulted in a great saving in both time and operating costs since the time of steel wheels. There are, however, certain basic fundamentals in the care of tires that should be followed carefully if the owner is to derive maximum benefit from his or her investment. First and most important is to maintain proper pressure for the work at hand. Your best guide to proper inflation is the operator's manual or instruction book tha ... [Read Article]
