Re: snow plow hydraulics question.
Posted by gene bender on January 31, 2007 at 06:57:30 from (67.55.226.214):
In Reply to: snow plow hydraulics question. posted by Brian in NY on January 31, 2007 at 06:35:03:
just put a vent plug in the unused port. I do the same with my rear blade on the B as i just use the port that lifts the blade. I drilled a hole in the plastic plug then turned the hole down so as not to get moisture in the cycl.
