Re: snow plow hydraulics question.
Posted by Hayfarmer on January 31, 2007 at 07:01:35 from (66.243.238.117):
In Reply to: snow plow hydraulics question. posted by Brian in NY on January 31, 2007 at 06:35:03:
normally when you use a 2 way cylinder as a 1 way you would put a breather plug in the other end. You can buy those or make one. That allows the air to leave. If there is leakage in the piston it may also blow oil out. With weight on it the oil should flow back quite rapidly.
