Re: snow plow hydraulics question.
Posted by Bob, seND on January 31, 2007 at 13:22:05 from (12.162.213.5):
In Reply to: snow plow hydraulics question. posted by Brian in NY on January 31, 2007 at 06:35:03:
Brian,
A little more expensive, but a very nice way to
go is to mount a spool valve on your tractor, run the lift all line to it, and back to lift-all reservoir. Leave your hydraulic pump running continuously through the spool valve. Continue to use your two way cylinder, and you now will have two-way hydraulics to the blade. It should lift the front of your tractor right off the ground.
Bob
