Re: How do you install a belly pump on a Farmall H
Posted by AH64Dattack on January 31, 2007 at 13:35:58 from (160.136.109.109):
In Reply to: How do you install a belly pump on a Farmall H posted by Neil Fuller on January 30, 2007 at 07:39:19:
I use the threaded rod trick myself with a floor jack to lift the heavy beast up an inch or two at a time and then spun the nuts up after it. The rods and nuts act as a safety and guide it up straight while the jack lifts so you don't have to keep alternating a couple a turns on each corner and its reduces the binding on the rods. Once you get to the top the jack holds it tight while you remove one rod at a time on diagonal corners to insert the bolts.
