Re: 826 vs 856- Same Drivetrain?
Posted by caseyc on January 31, 2007 at 19:00:15 from (66.115.192.148):
In Reply to: 826 vs 856- Same Drivetrain? posted by Jim Allen on January 31, 2007 at 18:39:29:
i'm sure someone with more experiance will chime in with a more educated answer but i'm gonna say they are not the "same" as you put it. i believe the 856 is around a 100hp and the 826 is in the 80-90 range if that. i'm sure the concept is the the same, but i would think the 856 would be a bit more stout, assuming we're comparing gear drives be cause the 826 was a popular hydro while i don't think the 856 was available in a hydro.
casey in SD
