Needle and seat are new and the float is OK/ has no leaks. Float could be out if adjustment, but I bent the tang up to raise it and it still does it. I actually think I have it adjusted too high now. I had this problem before and after rebuilding the carb. I have to check to see if it is catching on the side of the bowl. It does it when I have to crank it for extended periods to get it to start. I also put an inline filter in the line before the carb and thats when all this started, but I cannot see how that would cause this.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
