Re: Super M Gas flow problem
Posted by gene bender on February 01, 2007 at 10:22:21 from (67.55.226.214):
In Reply to: Super M Gas flow problem posted by AOOC on February 01, 2007 at 08:55:00:
Yes you can have an air lock i would loosen the fitting at the carb and let the gas run and see how much flow you have mite need to drain the tank and remove the sediment assy then blow out the passages as the intake can get pugged it will let some gas thru but not enough flow to keep carb full.
