Re: need your help with my H
Posted by rust collector on February 01, 2007 at 13:04:30 from (130.18.53.109):
In Reply to: need your help with my H posted by Pat-CT on February 01, 2007 at 12:49:50:
Sounds like a governor or govner connection problem to me. If carburator has been removed before this problem began, probably did not reassemble the carburator to the governor linkage correctly to the buterfly shaft of the carburator. Could also be loose or broken spring or other components in the governor.
